June 6, 2022 at 9:58 am FAQParticipant FAQParticipantYes. Follow the procedure below:
 1. Close Mechanical Window.
 2. Open the Parameter Set Window
 3. Right Click on desired Design Point Name in the Table of Design Option window and say Set as Current.
 4. Up on opening the Mechanical Window loads the results of selected design point.
 For this to work, Results of Design Point must be saved before solving.
 You are navigating away from the AIS Discovery experience
