Does ANSYS provide methods or tools to optimize the constants of a Chemkin reaction mechanism for better comparison with experiment?
June 6, 2022 at 8:33 am
FAQParticipantWe currently do not have rate coefficient optimization capabilities. The next best thing to do is to run a sensitivity and rate analysis in Chemkin under the conditions of interest. Chemkin sensitivity and rate analysis are two powerful tools that can identify the most important reactions under specific conditions. These reactions can then be manually modified or further parameterized for uncertainty analysis on their rate coefficients.
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- How can volume fraction be plotted in a species transport simulation?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
