June 6, 2022 at 8:33 am
FAQParticipantForte uses chemistry files in CHEMKIN format. The following steps can be followed to update or create a new chemistry set (update chemical mechanism):
1. Go to Utility> Preprocessing and unarchive the mechanism if the provided chemistry set is in .ckzip format (CHEMKIN archive)
2. Click new Chemistry Set, browse to and select the Gas-Phase Kinetics file and the Thermodynamics data file
3. Run the Pre-Processor to process the chemistry files
4. On the Chemistry dialog, import the chemistry set
5. Browse to the chemistry set and view it to verify correctness
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- How can volume fraction be plotted in a species transport simulation?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
