June 6, 2022 at 8:33 am
FAQParticipantIn ANSYS Fluent the dimension of the molecular weight is expressed in kg/kmol (kg/kgmol = kg per 1000 moles). So to get the correct input of heat of vaporization or in general the standard state enthalpy of particular fluid at a reference temperature for Fluent the conversion below is required:
standard state enthalpy in [J/kg]* Molar Mass [kg/kgmol] = Latent Heat in [J/kgmol ] Keywords: Latent Heat, kg/kmol, molecular weight
- Guidelines for Courant Number for steady and transient simulation.
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
