Tagged: ansys, Control Systems, Designing Embedded Systems, Embedded Software, Embedded Systems, Embedded Systems Programming, Esterel Technologies, Model-based Systems Engineering, Safety Critical Applications, Safety Critical Software, SCADE, SCADE Project, SCADE tutorial, Software Testing, Test Automation
June 3, 2022 at 1:43 pm
Watch & Learn
ParticipantIn the previous videos of the SCADE Test playlist, we have seen the planning and test data production, the model execution on host, and now I will explain to you the model execution on target with SCADE Test Environment for target execution. SCADE Test generates test harnesses for the following target test environments: LDRA TestBed, IBM RTRT and Vector Software VectorCAST.
- Scade One – Bridging the Gap between Model-Based Design and Traditional Programming
- Scade One – An Open Model-Based Ecosystem, Ready for MBSE
- Scade One – A Visual Coding Experience
- How to Verify a Model on Host with SCADE Test? (Part 4 of 6)
- Using the SCADE Python APIs from your favorite IDE
- Introduction to the SCADE Environment (Part 1 of 5)
- ARINC 661: the standard behind modern cockpit display systems
- How to integrate multiple SCADE models into one executable
- Scade One – Democratizing model-based development
- How to Generate Code with SCADE Display (Part 6 of 6)
