October 28, 2021 at 2:49 pm
NimaNZ
SubscriberHi everyone
I have a building with an opening. The opening has thickness but I want to add zero thickness fins perpendicular to the opening at the centre of the opening (like centre pivot window). When I draw the surface and define it as a wall inside the Space claim, in fluent these walls disapear.
I was wondering if there is any solution for this?
October 28, 2021 at 3:18 pmRob
Forum ModeratorThe surface isn't passed into the Meshing tool as it's not recognised. The easy work around is to model the object with a relatively high thickness and only label one face as a wall. You mesh the thickness to be no finer than you'd model the bulk and sorted.
October 28, 2021 at 4:13 pmNimaNZ
SubscriberThat's exactly the problem. What you're saying is that I should determine the body of that fin as fluid in Mechanical and only wall side as a wall? or just to be smaller than the grid side it cannot capture the effect of thickness and it can be solid?
October 28, 2021 at 4:38 pmRob
Forum ModeratorThe thickness cannot be smaller than a cell, I'll leave you to try it out. Yes, create a body with a "sensible" thickness and assign one surface as a wall: the others should either be left alone or defined as interior.
October 28, 2021 at 4:54 pmNimaNZ
SubscriberThank you so much for the details, it is much appreciated.
October 29, 2021 at 8:48 amRob
Forum Moderatoryou're welcome. Check the manuals for "baffle" too, I'm sure there's a proper way of doing it, but I've been using the workaround for years.
November 4, 2021 at 3:04 pmNimaNZ
SubscriberThank you so much ; when dealing with thin S-shaped louvres at the opening, I should check if it's working or not.
Viewing 6 reply threads- The topic ‘Zero thickness wall inside the domain’ is closed to new replies.
6420
