June 11, 2020 at 12:49 am
OceanZhou
SubscriberIs there a way to impose a zero-gradient boundary condition at the outlet for compressible flow? Such a condition is in OpenFOAM and I'm trying to replicate an OpenFOAM simulation in ANSYS Fluent and am having severe trouble with this.Â
Furthermore, the OpenFOAM simulation I seek to transfer over has boundary conditions for velocity and pressure at the inlet. Is this possible to do in ANSYS Fluent?
June 11, 2020 at 3:39 am
Kalyan Goparaju
Ansys EmployeeHello,Â
The outflow boundary condition is a zero gradient bc available for incompressible flows in Fluent. For compressible flows, you can try the pressure far-field boundary condition. Please look at the link below.Â
At the inlet, you can use a mass flow inlet, where you define the velocity (in terms of mass flux) and the static pressure. You can also use a pressure inlet, where you define the total and the static gauge pressure in such a way that the velocity at the inlet is what you are looking for.Â
Thanks,
Kalyan
- The topic ‘Zero Gradient Boundary Condition’ is closed to new replies.
5889
1306
