February 15, 2025 at 1:52 pm
2425736529
Subscriber我模仿着这篇论文做了一个天线,他的激励我认为应该是在曲面上的(如果不是的话请您帮我指正一下),但是在往上加激励的时系统报错显示端口要在“same plane”,我尝试了好久还是没能解决,希望大家可以给我一些帮助。
February 18, 2025 at 7:06 am
Jie Yan
Ansys Employee激励通常需要加在一个平面上的,可以是多边形或者圆形,不会建议加在曲面上的。
Ansys Innovation Space
- HFSS Incident Plane Wave excitement mode
- Ansys Maxwell 3D – eddy current
- Difficulty/Obstacle: “Parasolid entry check failed for part:”
- Simplorer+Maxwell Cosimulation results and Maxwell results mismatch
- Maxwell circuit – PWM
- Ansys-MATLAB Co-Simulation
- Plotting Ex, Ey and Ez in vector forms individually
- Calculating E-field tangential to a 2D resonant structure on a sapphire chip
- Compute near field simulation with current
- Y wiring method and the start and end points of winding.
897
599
591
418
