April 30, 2024 at 7:07 am
yusuf uzun
SubscriberHi,
I am using Semi-Mechanistic Boiling(SMB) Model to model boiling in engine water jacket. As ı understood, SMB model uses Ystar value to determine the referance temperature, velocity.Also the SMB model use that reference values to calculate some fluid properties and some variables. The calculations differ when Ystar value change.Â
So, what Ystar value should be selected?
April 30, 2024 at 2:13 pm
Ahmed Hussien
Ansys EmployeeHi Yusuf, please check the documentation for the definition of ystar as shown in the screenshot 25.4. Setting Up the Mixture Model (ansys.com). The point here is to calculate the reference values away from the boiling wall to have a relatively homegenous temperature. Thus, a high value of 250 is assigned as default. You may conduct a sensitivity study and try different values and assess the effect on the results.
May 2, 2024 at 8:45 am
yusuf uzun
SubscriberIs calculating the Reference variables far from wall more accurate than close to wall?
- The topic ‘Ystar Value for Semi-Mechanistic Boiling Model’ is closed to new replies.
5729
