July 31, 2024 at 9:01 am
지완 서
SubscriberI performed a turbulence simulation using RANS.
I want to analyze the y+ values at the boundary of the model.
Using the contour option, I can observe the turbulence - y+ values on the model boundary and by integrating along the boundary, I can obtain the average y+ value.Â
Which value should I consider to be accurate, as the results differ?
Thansk :)
July 31, 2024 at 9:12 am
Forum ModeratorIntegrating what along the boundary?Â
July 31, 2024 at 9:18 am
지완 서
SubscriberI integrated over the surface of the analysis model.
July 31, 2024 at 9:30 am
Forum ModeratorYou're asking why the integral and the average are different? The various surface reports are covered in https://ansyshelp.ansys.com/public/account/secured?returnurl=/Views/Secured/corp/v242/en/flu_ug/flu_ug_chp_report.html
August 1, 2024 at 4:15 am
지완 서
SubscriberThe specific question is as follows:
We can observe the y+ value through surface integral and contour in the turbulence section. I am curious why the two y+ values observed here are different.
The y+ value obtained through surface integral makes sense to me. It is calculated by summing the individual y+ values in each region and then dividing by the area.
However, when looking at the y+ value from the contour on the boundary surface of the model being analyzed, there is a significant difference in the values. This discrepancy is what I am curious about.
Finally, I would like to know which method of evaluating the y+ value is generally considered standard.
August 1, 2024 at 1:55 pm
Forum ModeratorDid you plot with node values on or off? The former will show some smoothing of the values, the latter the actual node (facet in this case) value.Â
- The topic ‘Y+ value in fluent’ is closed to new replies.
5824
