Electronics
Electronics
Wrong value of flux linkage of a coil in Axial YASA motor
    • mdjula00
      Hi, i am having trouble calculating flux linkage in transienst Maxwell 3D simulation of Axial flux YASA motor. I am doing no load analysis with 12 poles and 9 slots motor. I calculate magnet flux on a surface of a coil and I multiply it by number of turns. The value is three times lower than value obtained by the software?? Can someone explain why is that, what am I doing wrong here?
      Thank you.
    • HDLI
      Hello Marko,
            Is number of turns for one coil or 3 coils? because you just calculate one coil's surface. The flux linkage may be for total coils in the model.
      HDLI
  • The topic ‘Wrong value of flux linkage of a coil in Axial YASA motor’ is closed to new replies.
