July 3, 2024 at 10:06 am
Isoth Madush
SubscriberI have the problem that the stress value (max. stress according to Mises) at the surface (Fig. 1, 334.47 MPa) does not match the evaluation of a path (Fig. 2, 343.33 MPa). The start of the path is at the same node as in Fig. 1 and extends vertically 10 mm into the component. 100 points along the path are considered. Furthermore, the course of the gradient within the first support points is strange. Both stresses are according to Mises, and the loadstep also matches.
It would be nice if you could help me. Thank you very much!
July 5, 2024 at 3:39 pm
danielshaw
Ansys EmployeeDid you try plotting the unaveraged Seqv?
- The topic ‘Wrong Stress Gradient’ is closed to new replies.
- BackGround Color
- Contact stiffness too big
- Element Birth and Death
- Python-Script to Export all Children of a Solution Tree
- Which equations and in what form are valid for defining excitations?
1495
1386
1209
