Write journal file for a unsteady job
    • KCHENG
      I am writing a journal file to sbbmitting my unsteady job to hpc cluster.My journal file is like this:
      rc probe-in
      sta-init
      time-step 0.001
      dual-time-iterate 2000 50
      wcd probe-out
      overwrite ok
      .out and .err:
    • Amine Ben Hadj Ali
      I recommend to record a journal with all commands you require. Fluent will just keep track of the correct commands. Under File start journal, you can start recording: that is the best way .
      /solve dti 2000 50
      Also, click into the text window and press Enter. You'll see a list of commands, type in the command you want and press Enter. Press Enter again to see the next menu list. Use q (Q) to move back up the tree.
      /file/rc probe
      Is the correct form and avoids issues with menu level mismatches as it uses the top menu level as the starting point.
  • The topic ‘Write journal file for a unsteady job’ is closed to new replies.
