LS Dyna
LS Dyna
Workflow for combining two geometry. 1 from Previous Sims, 1 from Spaceclaim.
    • Ben_Ben
      I am currently having a workflow issue. I have simplified it down so it is easier to explain.
      I have to do a simulation geometry A and geometry B. Geometry A is fixed at the sides and Geometry B is inflated with pressure. Frictionless contact is applied between A and B.
      Geometery A is comprised of three shell bodies of differing material properties. But they shared topology and have a coincident mesh. Geometry A is the picture below.
      Geometry B is comprised of 1 shell body. Geometry B is the result of previous complex simulations. Geometry B is included into the model with Dynain. Geometry B is the image below.
      The issue arises here. I can't combine a Dynain geometry (geom B) with a geometry from spaceclaim (geom A). To get around this I performed a small relevant part of the simulation on Geom A so that I could access it as a Dynain file. I then combined the two Dynain files from Geom A and B.
      The next issue arises here. When you access geometry via Dynain any bodies that share coincident nodes are combined into one body. So for geom A, I lose the three individual parts and they are combined into one. This means I can't then apply differing material properties to the parts. See the result of accessing geom A from Dynain below.
      Questions:
      - Can I combine Geom A and Geom B in a different way?
      - Is there anyway to maintain the individual bodies from Geom A after dynain?
    • Reno Genest
      Hello Ben,
      You can create geometry A using a Mechanical Model system, import the dynain (geometry B) using an External Model system, and combine them together in an LS-DYNA system:
      Note that you will have to rename the dynain file to dynain.k to be able to import it using the External Model system.
      Have you tried the above? I am using Ansys WB 2023R1 and the above workflow works.
      Also, make sure to set the mesh preference to "Explicit" in the Mechanical Model system:
      Let me know how it goes.
      Reno.
    • Ben_Ben
      Hi Reno,
      Just updated my model and it ran to completion. Thank you so much for this suggestion!
      Kind Regards,
      Ben
    • Reno Genest
      Hello Ben,
      Sounds good. I am glad it worked  for you.
      Have a good day!
      Reno.
  • The topic ‘Workflow for combining two geometry. 1 from Previous Sims, 1 from Spaceclaim.’ is closed to new replies.
