Workbench Fluent meshing stuck at “Generating Prisms” for new design points.
    • SemB
      Hi all,
      I've setup a parametric CFD study in Ansys Workbench. For DP 0 it works well. DP 1 only has a very small modification in the geometry. The geometry is generated correctly, but then at the meshing, it gets stuck (no error, but takes forever) at "Generating prisms". I don't think geometrical modification of DP 1 wrt DP 0 could be the issue, as it is a very minor modification, just to test the workflow.
      Any ideas how to troubleshoot?
Viewing 0 reply threads
