Ansys Products
Ansys Products
Workbench 19.2 Unexpected Error
    • aschef
      Hello Everyone,
      After Installing Ansys Student as Admin and starting Workbench 19.2 (from Start and from the installation folder) as Admin, too, I get this error message.
      I tried changing my computername and system language to english (us), redownload, -installing and -starting but nothing works.
      Thanks in advance.
      Alex
    • JakeC
      Hi Alex,
      It sounds like there may be a dll conflict in your path.
      Please try the following:
      Start -> type in cmd -> click on the command prompt
      Enter the following commands, and please adjust as necessary to match your machine:
      set Path=C:windowssystem32;C:windows;C:windowsSystem32Wbem;
      cd "c:program filesansys incv192Frameworkbinwin64"
      runwb2
      Please let us know if that helps.
      Thank you,
      Jake
    • aschef
      Hello Jake,
      thank you for your quick reply, but unfortunately it still doesn't work. (same error)
    • JakeC
      Hi Alex,
      In the command prompt, please type "set" and press enter.
      Then post a screenshot of the results.
      Also please try opening windows file explorer and paste the following into the path/address bar at the top:
      %APPDATA%ansys
      Rename the v192 directory to be v192_old
      Next click on Start -> Type in DxDiag.exe -> Click on DxDiag
      Post a screenshot of each of the tabs.
      Next open an Admin Command Prompt Start -> type cmd -> Right click on Command Prompt -> Run As Administrator
      Enter the following commands:
      cd windowssystem32
      regsvr32.exe ole32.dll
      regsvr32.exe atl.dll
      regsvr32.exe oleaut32.dll
      regsvr32.exe scrrun.dll
      regsvr32.exe jscript.dll
      regsvr32.exe vbscript.dll
      Next click on start -> Ansys 19.2 -> Product and CAD configuration
      Click on "Check for Required Prerequisites" and post a screenshot of the results.
      Click on "Install Required Prerequisites" (and follow the prompts)
      Click on "Add >NET Security Exception"Click on Configure Products and CADS (and follow the prompts)
      Now try running Workbench again.
      If that doesn't work, please right click on the Workbench shortcut in the start menu and select "Run As Administrator" and see if that works.
      Thank you,
      Jake
    • aschef
      Hi Jake,
      "Set" output in cmd:
      Output of
      DxDiag_1:
      DxDiag_2:
      DxDiag_3:
      DxDiag_4:
      Required Prerequisites:
      Sadly, still the same error.
      Thank You,
      Alex
    • tsiriaks
      Hi aschef ,
      Just for a kick, if you run this directly
      C:Program FilesANSYS IncANSYS Studentv192commonfilesIronPythonipy.exe
      Do you see a similar error ?
      If so, there is something on the systems that is messing with IronPython
      I'm not sure if it's related but it might be worth trying to uninstall that IronRuby and see if it makes any difference.
      Thank you,
      Win
    • aschef
      Hi Win,
      yes, there was a similar error and yes it was related! After deinstalling IronPython, Ansys started normally.
      Thank you very much!
      Alex
    • tsiriaks
      Perfect !
      Thank you for the update.
      Win
Viewing 7 reply threads
  • The topic ‘Workbench 19.2 Unexpected Error’ is closed to new replies.
