November 13, 2020 at 6:50 pm
Bakhtiyar
SubscriberHello,
I am trying to mesh a domain filled with air from which a wing was substracted. The capture curvature option is on. The mesh at the middle of the leading edge is ok, but coarse near the root and tip edges. I don't understand why.
November 15, 2020 at 11:10 pmpeteroznewman
SubscribernYou can add a sizing control to the faces of the wing.nNovember 16, 2020 at 2:06 pmBakhtiyar
SubscribernThat's what face sizings gave me. Anyways, I used body of influence, which worked well nNovember 17, 2020 at 5:21 amKeyur Kanade
Ansys EmployeeYes, BOI would work. nThe best way is to split the face and create leading edge in geometry. Then you will get better control on mesh at the leading edge. nRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help linksnnNovember 19, 2020 at 12:47 pmBakhtiyar
SubscribernThank you for your answernNovember 23, 2020 at 4:35 amKeyur Kanade
Ansys EmployeeCan you please mark this as answer to help others on the forum. nNovember 23, 2020 at 9:28 amBakhtiyar
SubscribernI can't find any button to mark itnViewing 6 reply threads- The topic ‘Wing meshing’ is closed to new replies.
