March 20, 2024 at 7:32 am
Ruchika Singh
SubscriberHi,
There are two excitations available in Ansys Maxwell for 2D transient analysis: voltage and current. I have observed that it is only possible to add Y connection in case of voltage excited windings but not for current excited windings. My questions are as follows:
- In case of current excited windings, what is the default connection assumed by Maxwell, star or delta?
- Can I get delta connection in Ansys Maxwell 2D tranient similar to Y connection?
Thank you very much!
Best Regards,
Ruchika
March 26, 2024 at 8:12 pm
GLUO
Ansys EmployeeHi,
Delta/Wye connection is only defined in the external circuit instead of in excitation. If you would like to use a start connection with current source, you only need two sources due to KCL.
GL
April 4, 2024 at 9:44 am
Ruchika Singh
SubscriberHi GL,
Thank you for your reply.
Best Regards,
Ruchika
- The topic ‘Winding excitation in 2D transient for Ansys Maxwell’ is closed to new replies.
1306
