November 29, 2021 at 3:22 pm
Dalyan11
SubscriberNovember 30, 2021 at 3:57 amFernando Torres
SubscriberHi Dalyan,
Please check if the target's body (plate) is set as flexible and apply a suitable material model like johnson cook if the target is metallic, mooney rivlin if it's rubber etc by going to Engineering Data. This could be the partial answer to what you are looking for. Thanks!
November 30, 2021 at 10:00 amDalyan11
SubscriberThank you for responding but didn't work
December 1, 2021 at 12:22 pmpeteroznewman
SubscriberPlease use File Archive to create a .wbpz file and attach that to your reply. I will take a look.
December 1, 2021 at 1:17 pmDalyan11
December 1, 2021 at 1:19 pmDalyan11
SubscriberPlease what is your ansys version to export the file for that?
December 1, 2021 at 5:03 pmpeteroznewman
SubscriberI am using ANSYS 2021 R2. You don't get a choice when creating the Archive.
December 1, 2021 at 5:32 pmDalyan11
SubscriberOk, also I'm using this version
December 1, 2021 at 9:48 pmpeteroznewman
SubscriberI am offering to look at your model to try to resolve the issue. There are two things you need to do if you want to take me up on this offer.
Save a .wbpz file
Use the paper clip icon at the bottom of your reply and attach the .wbpz file.
December 1, 2021 at 10:53 pmDalyan11
SubscriberDecember 2, 2021 at 12:59 ampeteroznewman
SubscriberFirst observation: There is a 0.0032 m gap between the bullet and the plate. This is a waste of time solving the motion to close the gap. It is best to put the tip tangent to the plate in CAD.
Second observation: The end time is 6.8e-6 seconds and the initial velocity is 450 m/s so the distance travelled in that time is 0.00306 m which is less than the gap.
The time must be long enough for the bullet to get to the back of the plate or 0.02 m to that would be 4.44e-5 s
December 2, 2021 at 12:02 pmDalyan11
SubscriberThank you for your help dear, if you help me for mashing also i will be so thankful.
December 2, 2021 at 12:44 pmpeteroznewman
SubscriberWhat is mashing?
December 2, 2021 at 12:55 pmDalyan11
SubscriberSorry y meshing not mashing
December 2, 2021 at 12:57 pmpeteroznewman
SubscriberWhat is wrong with the mesh? Why do you want to change it?
December 2, 2021 at 12:58 pmDalyan11
SubscriberBecause the automatic meshing is not accurate enough to gives a good results
December 2, 2021 at 1:01 pmDalyan11
SubscriberBecause the graphs is not accurate so i believe that the mesh that affects it
December 2, 2021 at 1:02 pmpeteroznewman
SubscriberWhat results are you looking at?
How do those results change with element size?
December 2, 2021 at 1:09 pmDalyan11
SubscriberI want a regular smooth graph, but that graph doesn't give me that result, for example the velocity and kinatic energy bo the bullet decrease and increase again and decrease, so that result it is not acceptable in real situation how the energy increase after it is decreased ?
December 2, 2021 at 2:11 pmpeteroznewman
SubscriberExplicit Dynamics solutions are well known to be noisy and often require filtering to obtain smooth curves.
Some of the noise comes from the large element size and using smaller elements will reduce the amount of noise in the results. Have you tried reducing the element size by a factor of 2? After you do that, reduce the element size by a factor of 2 again for a total of a factor of 4 from the original mesh. Is the raw data on the energy becoming smoother? Do you know how to low pass filter data?
Viewing 19 reply threads- The topic ‘why the bullet does not penetrate the plate and does not go though it? pleas help’ is closed to new replies.
6279
