February 15, 2023 at 4:19 amJeff Arris
Why would the compatibility utility be failing this card for not having 4Gb of RAM when in the listing below with the GPU 2 information it literally says it has 4Gb of RAM ?
February 15, 2023 at 5:00 amDevendra BadgujarForum Moderator
Hello Jeff Arris
Please try disabling Intel graphics on the machine and see if that helps. Also, can you confirm which Discovery version you are using?
Although minimum 4Gb is required, 8 GB dedicated GPU RAM is recommended. Please try rolling back to an older version of the graphics driver and see if that helps (avoid the 5xx.x graphic card driver, as it has shown some other issues).
Regards.Â
February 16, 2023 at 4:20 amJeff Arris
OK.
Will try.
- The topic ‘Why is GPU not good enough with 4Gb RAM?’ is closed to new replies.
Ansys Innovation Space
- Data Center Simulation
- Unable to attach geometry 2024 R2
- Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
- How to provide blade angles in bladegen.
- DXF file loaded incorrectly
- Crash by using Script Editor
- plugin error failed to import assembly from spaceclaim
- Overlapping contact face
- Temperature’s Distribution not available in Refine Mode ?
- Thermoelectric Cooler Model
513
488
225
209
