October 2, 2020 at 7:39 pm
SACHIN17IITMADRAS
SubscriberOctober 5, 2020 at 11:53 amKarthik Remella
AdministratorHello,nI'm moving your question to the Discuss Simulation -> Fluids for better alignment.nAlso, could you please embed the screenshot directly into your post? As Ansys employees, we are not able to download attachments from the forum.nHow are you plotting the mass flow rate contour? Could you please share a screenshot?nThank you.nKarthiknOctober 9, 2020 at 5:48 amOctober 13, 2020 at 2:08 amKarthik Remella
AdministratorI'm sorry - but I don't completely understand your question. Could you please elaborate?nThanks.nKarthiknOctober 26, 2020 at 7:22 amSACHIN17IITMADRAS
Subscriberi have created an interface in ICEM CFD and similarly defined in CFX, but after getting the result when i plotted the result for the variable mass flow it showing like the image i send you. and similarly when i am calculating mass flow as variable in function calculator, it is not showing the required value because a closed surface should follow conservation of mass law.n
n
October 26, 2020 at 7:51 amAmine Ben Hadj Ali
Ansys EmployeeI do not understand the question: Can you report the massflow()@ the boundaries in question.nViewing 5 reply threads- The topic ‘why i am getting mass flow contours in sections as on a single surface.’ is closed to new replies.
4613
1520
1386
1209
