August 19, 2019 at 8:55 pm
MMS1148
SubscriberI am doing 2D static Structural Analysis of a cylinder with ID=1.3125 in OD= 1.097 in. Pressure of 0.2 Mpa is applied on the ID in outward direction. Model is constrained by applying cylindrical support ( Radial=Free, Tangential =fixed).
I have attached the result of Normal Stress along x-direction. I am unable to understand how these circular patterns be interpreted (If I am doing analysis right way)
Please help me understanding the results.
August 20, 2019 at 12:05 am
peteroznewman
SubscriberYou plotted the Normal Stress component in the X-direction like this:
The blue part can be understood by knowing that the radial stress on the inside face is a compressive stress of 0.2 MPa. If you create a Cylindrical Coordinate System, you can plot the radial stress like this.
The red part of the Normal X-axis Stress can be understood by knowing that the hoop stress on the inside face is a tensile stress of 1.13 MPa and that can be plotted in the Cylindrical Coordinate System on the Y-axis.
August 20, 2019 at 12:21 am
MMS1148
SubscriberGot it. I really appreciate your time and help. I was confused and I was not able to find its explanation from any of the other internet resource. You made my day.
August 20, 2019 at 12:28 am
peteroznewman
SubscriberGreat, please mark my post with Is Solution to show other members that the discussion is Solved.
- The topic ‘Why am I seeing a circular pattern of stresses in 2D Plain Stress results of a cylinder’ is closed to new replies.
6465
