December 22, 2020 at 12:41 am
bibas
SubscriberGood Evening,
An upward force is being applied to both side pieces (green and yellow) in order to see the deformation in the center part (greu). What kind of joints/connections should I insert?
Thank you in advance for any answer
December 22, 2020 at 3:30 pmRahul Kumbhar
Ansys EmployeeYou can use 'revolute joint' as described in the Ansys Help.nhttps://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v202/en/wb_sim/ds_Joints_types_revolute.htmlnDecember 22, 2020 at 4:57 pmbibas
SubscriberThe real structure does have joints but they act like they are almost fixed.nAnother doubt i am having is about the equation force. Since the equation does have x variable i can only insert the equation in pressure and not in force, do i need to divide by the area?nDecember 24, 2020 at 7:50 amRahul Kumbhar
Ansys Employeeyou should be able to insert force as a function.nViewing 3 reply threads- The topic ‘Which joint is correct?’ is closed to new replies.
5169
1836
1387
1249
