Which command is used to find out the the following in fluent with meshing module?
    • omkarmadhekar
      Total no of elements nTotal no of nodes nSkewness factor northogonal quality nAnd should I use this command in the console of fluent or console of fluent with meshing module. n
    • RK
      You can find all these in the Mesh tab in the ribbon in Fluent Meshing. n
  • The topic ‘Which command is used to find out the the following in fluent with meshing module?’ is closed to new replies.
