November 2, 2023 at 1:59 am
mmia1
SubscriberHi
I am planning to use beam element to model my pipes which will experience large deformation. Does anyone know which beam element Hughes-Liu vs Belytschko-Schwer available in LSDyna will be good for large deformation analysis?
November 2, 2023 at 1:50 pm
Jim Day
Ansys EmployeeI think it’s safe to assume that nonlinear material behavior accompanies the large deformation in your application. H-L beams are integrated beams; B-S beams are resultant beams. I would recommend Hughes-Liu beams for a number of reasons, including being able to specify the cross-section shape and number/location of cross-section integration points and also having access to a wider variety of nonlinear material models.
- The topic ‘Which beam element for large deformation (Hughes-Liu vs Belytschko-Schwer)’ is closed to new replies.
