August 29, 2024 at 2:28 am
3385396099
SubscriberIn Fluent, when two fuels are mixed for the same inlet, how to set their respective molar ratios? If the eddy dissipation model of premixed combustion with component transport is not used, I tried to use different names for the same inlet, but the two fuels were still not separate when setting the inlet parameters
September 24, 2024 at 2:28 pm
Vijay Narayan
Ansys EmployeeHi,Â
I'm summarizing my understanding of your statement and the response. Please correct me if i have misunderstood your requirement.
a) You have a case where the inlet is a premixed system of two fuels and you want to specify the mass fraction or mole fraction. If you use the Finite Rate/Species transport model - if the fuel species are included in the mechanism file, then you can specify their respective molar fraction in boundary conditions. Incase, you are using the PDF based models, then you will specify the fuel stream as the premixed system of two fuels and specify their respective mass fraction in the boundary tab.Â
Since only the fuel stream is premixed and the oxidizer is coming seperately, you can use the non premixed model or partially premixed model for PDF based approach. I hope this answers your query.
