August 18, 2022 at 5:18 pm
manelaero2020
SubscriberHi everyone ?
I am simulating airflow over a wing. The flow is turbulent, so I have put a 6 inflation layer near the wall, the height of the first is 4 micrometers with a progression rate of 1.1.Â
My problem is the next :Â
The value of the contours of Y+ is minimal (order of e-10)Â Â
What is the significance of such a small Y+? Do I have well resolved my flow near the wall or is there a problem somewhere?Â
As a remark, the computation has well converged ( residual of e-8 reached), and the lift coefficient curve has reached a constant value (plateau) at the end of the computationÂ
Thank you a lot
I have used Fensap for the aerodynamic part of the computation ( the equivalent of fluent) / Turbulence model is spalart AllmarasÂ
August 19, 2022 at 11:48 am
Danica
Ansys EmployeeHi,
Although the Y+ value can be useful in defining the height of the first cell next to the wall, the whole boundary layer needs to be refined appropriately for accurate results so it's important to also take this into account. Have a look at the response other thread that you have posted: questions about inflation layers /turbulence (ansys.com)
- The topic ‘What is the signification of a very small Y+ value ?’ is closed to new replies.
6485
