September 7, 2021 at 11:08 am
Tony9473
SubscriberRPM of rotary lobe pump is about 100 to 150
Working principle of
rotary pumpThe pumping action of the rotary lobe pump principle is generated by the counter rotation of two pumping elements (rotors) within a chamber (rotor case). ... As the rotors pass the suction port, the cavity generated increases creating a pressure decrease, which induces the pumped medium to flow into the rotor case.
https://marinerspoint.in/rotary-lobe-pump-working-diagram-applications/
September 8, 2021 at 12:57 pmRK
Ansys EmployeeHello,
I am not sure about the question you are asking. Is this related to Fluid simulation? If so, can you please be more specific in your question relating to simulation so that we can assist you better. Thank you.
Viewing 1 reply thread- The topic ‘What is the rmp of lobe pump and it’s working principle ?’ is closed to new replies.
5884
1306
