July 4, 2021 at 12:20 pm
shadman_shahid
SubscriberI was simulating a file to obtain a bandstructure of a crystal. However, in that file, some of the time monitors in the bandstructure group just don't generate any data. Always these monitors don't display any result. What can be the possible reason, and how to avert this problem?
July 5, 2021 at 6:13 pmKyle
Are the monitors inside the simulation region? If they're outside the simulation region they will not produce any data.
July 6, 2021 at 2:14 pmshadman_shahid
SubscriberOkay. So I noticed that some of the time monitors were one the blue region (the symmetric portion of the boundary). That's why those monitors were not giving results. It was very straightforward. I didn't check that portion.
Thanks. That solved it.
September 6, 2023 at 1:01 amMuhammad Danial Haziq Azizan
SubscriberIt is just randomly locating the position of bandstructure TimeMonitor? Then check at simulation and memory requirements. like this
ÂMonitorsÂTime Monitor, ::model::bandstructure::m1: 510 kB (0.6%)Â510 kB saved to fsp fileTime Monitor, ::model::bandstructure::m2: 510 kB (0.6%)Â510 kB saved to fsp fileTime Monitor, ::model::bandstructure::m3: 510 kB (0.6%)Â510 kB saved to fsp fileTime Monitor, ::model::bandstructure::m4: 510 kB (0.6%)Â510 kB saved to fsp fileTime Monitor, ::model::bandstructure::m5: 510 kB (0.6%)Â510 kB saved to fsp fileTime Monitor, ::model::bandstructure::m6: 510 kB (0.6%)Â510 kB saved to fsp fileTime Monitor, ::model::bandstructure::m7: 510 kB (0.6%)Â510 kB saved to fsp fileTime Monitor, ::model::bandstructure::m8: 510 kB (0.6%)Â510 kB saved to fsp fileTime Monitor, ::model::bandstructure::m9: 510 kB (0.6%)Â510 kB saved to fsp fileTime Monitor, ::model::bandstructure::m10: 510 kB (0.6%)Â510 kB saved to fsp fileSeptember 6, 2023 at 11:02 amMuhammad Danial Haziq Azizan
SubscriberHow many sources are required to get the bandstructure? is it fixed to 6 dipole source? 3 at the top and bottom on XY view?
Viewing 4 reply threads- The topic ‘What is the possible reason that one might not get any data in time monitors?’ is closed to new replies.
6625
1311
