What is the impact of having a pipe made of rough material on the flow?
    • Karthik Remella
      Administrator
      Hello Experts,
    • prajput
      Hello @Kremella ,
      The flow over a rough wall generally leads to higher levels of friction pressure losses.
    • Karthik Remella
      Administrator
      Thanks for your response @prajput , Is there a way to calculate the friction losses?
    • prajput
      Yes, you can calculate the friction losses using the Darcy-Weisbach equation. The pressure losses are proportional to the length of the pipe and the Darcy-Weisbach friction factor:
      delta_P / L = f_D * (rho / 2) * (V_avg^2 / D )
      where,
      delta_P - pressure drop
      L - pipe length
      f_D - friction factor
      rho - fluid density
      mu - fluid dynamic viscosity
      V_avg - average fluid velocity
      D - pipe diameter
      This equation is valid for incompressible flows.
  • The topic ‘What is the impact of having a pipe made of rough material on the flow?’ is closed to new replies.
