July 31, 2020 at 3:29 pm
Akismet
SubscriberWhat is the difference between hardness, toughness, and strength in practical physics terms?
Karthik Remella
AdministratorStrength can be various strengths such as Tensile, Compression or Flextural. In general strength means the maximum stress the material can withstand. In the above diagram point D represents the Ultimate Tensile Strength (UTS) of the material. Above this, the material starts to neck and then finally breaks.Toughness is the extend to which a material absorbs energy before it breaks during a tensile test. The area under the stress-strain curve is also an indication of the toughness of the material.Hardness is a surface property of the material . It represents the visco-elastic response of a material. In general a material is hard if it has a high tensile strength.
July 31, 2020 at 3:30 pm
Akismet
SubscriberThank you @Kremella  !
- The topic ‘What is the difference between hardness, toughness, and strength in practical physics terms?’ is closed to new replies.
1324
1047
