July 31, 2020 at 4:01 pm
Karthik Remella
AdministratorWhat is a statically determinate system?
Dragana Jandric
Forum ModeratorHello @Kremella . When the total degree of freedom in a system is equal or less than 0, we say it is static determinate. It also means the system does not form a mechanism (in plainer words: it does not move).
July 31, 2020 at 4:02 pm
Akismet
SubscriberMay be this example will help: consider three rods connected to each other by pin joints. Once fixed, the three rods cannot move with respect to each other without deforming the other rods. On the other hand, if you have four rods of equal lengths connected to each other by pin joints, they can move with respect to each other without deforming themselves or the other rods. So the three rod system is statically determinate, while the four rod system is statically indeterminate.
Dragana Jandric
Forum ModeratorIn structural mechanics, if a structure is statically determinate then static equilibrium equations are sufficient for determining internal forces and reactions on the structure.
- The topic ‘What is a statically determinate system?’ is closed to new replies.
