What does the error “eXt of material … is 0 or negative” mean?
    • matorres
      I've just started to use ACP to simulate some composite structure. When I want to solve the problem in ACP(Post) I always get the message "eXt of material ... is 0 or negative. Check material definition or set global strain limits." and I can't figure out what it means.
      Does someone has the answer for this?
      Thank you!
    • Manish Dubey
      Could you please write the complete error message? It is not clear which parameter became 0 or negative.
      Thanks
      Manish
  • The topic ‘What does the error “eXt of material … is 0 or negative” mean?’ is closed to new replies.
