July 7, 2019 at 11:59 am
HungNguyen
SubscriberHi everyone,
I'm Hung Nguyen from Vietnam. Currently i'm doing my thesis using Ansys Fluent.
I've finished calculation for my model and trying to export a chart with X axis is temperature and Y axis is location.
I choose Location>line>select my point A and B> Chart
In the chart properties I choose X axis is Chart count and Y axis is temperature.
But can I understand that way: Chart count is the length of the line I have chosen cuz the unit of chart count is not m or mm
Thank you very much.
July 8, 2019 at 4:37 am
Amine Ben Hadj Ali
Ansys EmployeeScreenshot please. -
July 8, 2019 at 8:09 am
July 8, 2019 at 8:17 am
July 8, 2019 at 8:52 am
Amine Ben Hadj Ali
Ansys EmployeeChart Count: The count of the data. Please select Your position along which the chart has to be plotted (X, Y or Z)
July 9, 2019 at 6:03 am
July 9, 2019 at 6:05 am
HungNguyen
Subscriberas you can see, the temperature is rising along the line.
Is the chart count in this case is the length of the line(in different unit)?
July 9, 2019 at 10:24 am
Forum ModeratorLooks like it: open the "x axis" and see what's available.Â
July 9, 2019 at 11:20 am
Amine Ben Hadj Ali
Ansys EmployeeSelect the coordinate my dear under "X Axis"...
July 11, 2019 at 9:33 am
HungNguyen
SubscriberOk I got it, thank you!!!
HungNguyen
SubscriberOK I got it, thank you very much!
July 11, 2019 at 10:53 am
Amine Ben Hadj Ali
Ansys EmployeePlease mark this as "Is solved"
- The topic ‘what does chart count meant?’ is closed to new replies.
- affinity not set
4167
1487
1363
1194
.jpg?width=690&upscale=false)
