September 12, 2024 at 4:11 am
nhanani4
SubscriberHi
My resarch is about get the horizontal force connector for multi-module floating structure.
The point I draw start at first module and axis at first module.
It necesary the x-axis at the middle arrangement?
it is effect the surge, heave motion of floating structure?
because i get 6dof motion actual response so higher from other paper that i refer.
this axis effect this below?
September 13, 2024 at 1:23 pm
saheed.yusuf
SubscriberHello,
My research is similar to yours but I am having some issues with my model. Can you help me pleaseÂ
September 13, 2024 at 2:20 pm
Shuangxing Du
Ansys EmployeeThe requirements of the global coordinate system used by Aqwa are
(1)Â Â its origin is on the mean water level.
(2)Â Â the z-axis points upwards.
October 3, 2024 at 1:40 am
nhanani4
Subscriber- so the origin i put in the first module and my paper refer the origin at the middle module that do not effect the surge, heave ,etc result?
- it is correct way i want to find the heave result (structure position > actual response > global z)? or heave result is from (structure position > RAO based response > global z):?
- it correct if heave get the -4.9 m get negative? my height hexagon is 20m.
