TAGGED: batch-command, batch-mode, commands, hpc, hpc-command-lines
January 11, 2021 at 8:16 pm
hcraik2016
SubscriberFor the research project I am working on we are analyzing a bridge section. However, the bridge section is about 50 meters in length resulting in a large number of nodes and elements.nThe model either has too many nodes for the version I have or is taking anywhere from a day to two days to get results. As a result i am looking to use the HPC my Institution has available, but I am not familiar with the commands needed to properly submit an ANSYS file to the HPC.nWould you be able to direct me to an ANSYS manual where i could find such command s or would you be able to suggests whcih commands will work.nnThe model is created using ANSYS Workbench and mechanical.n -
January 12, 2021 at 10:49 am
ashish.khemka
Forum ModeratornnPlease see if the following link helps:nnnRegards,nAshish Khemkan
- The topic ‘What are the commands for running an ANSYS file on a HPC?’ is closed to new replies.
