Weld Material Properties
    • Sam Fares
      Hi All,
      What are the material properties needed to simulate the weld behavior? This is electrode 70 that is used for the filler material. Weld material  has a yield strength of 57000 psi and ultimate tensile strength of 70,000 psi.
      Thanks,
      Sam
    • Keyur Kanade
      Moving to structural mechanics category for better response.
      Keyur
    • Sandeep Medikonda
      You can either use joints or contact formulations as discussed in this example of the Technology Demonstration guide.
      Sandeep
    • Sam Fares
       I am asking about the Weld material physical properties  that i need to put inside the Engineering Data A2.
      Thanks,
      Sam
    • Sandeep Medikonda
      Properties you want to use are dependent on the material models you are using and the analysis type you are carrying out.
      See this example for sample material properties. You can start with Elastic and use a BISO plastic Material model.
      Sandeep
Viewing 4 reply threads
  • The topic ‘Weld Material Properties’ is closed to new replies.
