TAGGED: material-properties, structural, wave-propagation
February 18, 2023 at 1:13 am
larito
SubscriberHello I am trying to create a wave that propagates through the pipe when I do 2-way coupling with Fluent. I have set a fluid geometry enternal pipe+ the volume in the back and set the external geometry as the solid. I have chosen water as the fluid and Plastic Pi as the solid. I have set the pipe as a fixed support and run the simulation for 20 seconds.Â
In the results I see a deformation that decreases linearly for a few mm until it vanishes. I played a bit with Young Modulus and now I will change the pressure inlet which is a UDF set to create pulse flow with 1000 Pa every other second.
I am not very familiar with structrular and my current suspicion is that the pressure is not enough at this point to create such behavior. Do you have any advice on what needs to be changed in order to achieve a wave propagation?
Thank you
February 20, 2023 at 12:42 pm
Ashish Khemka
Forum ModeratorHi,
Please see if the following link helps:
Reporting an error in Anisotropic Elasticity Matrix calculation (ansys.com)
Ashish Khemka
February 20, 2023 at 6:35 pm
larito
SubscriberHello Ashish,
Unfortunatelly it does not help me but thank you very much for your reply. I am not clear on how to imitate pressure wave propagation in Ansys that is all. If you have any advice on that I would really appreciate it.
Best regards
February 21, 2023 at 9:26 am
Ashish Khemka
Forum ModeratorHi,
I shared the wrong link and I apologize for the same. Please see if the following link helps:
Generating Pressure Wave (ansys.com)
Ashish Khemka
February 21, 2023 at 11:49 pm
larito
SubscriberÂ
Thank you once again. Do you happen to know where I can find the Expicit Dynamics documentation?Â
Thank you
EDIT: I found a bunch of stuff in Ansys Learning hub
February 22, 2023 at 1:21 am
larito
SubscriberHello again,
I was wondering if you have a tutorial in mind because I am going through infinite amount of pages and honestly I am getting more confused. I want to see an example to understand what is happening.
Best regards
- The topic ‘Wave propagation in Structural’ is closed to new replies.
5984
1307
