Wave generation simulation (UDF error)
    • abdoomer199
      I am trying to simulate sloshing water in a moving tank (sinusoidal motion)
      I used (Simulation of Wave Generation in a Tank) tutorial, but I could not load the UDF file, then I searched for the solution but it didn't help
      What should I do ?!
    • DrAmine
      You need to compile that UDF or interpret before trying to load. You can use a Fluent Expression based profile for that without any UDF.n
    • abdoomer199
      Thank you for your helpnI did that but I did not notice any movement in the fluid inside nn
    • abdoomer199
      Does this has any thing related to Dynamic mesh ?!n
    • abdoomer199
      https://www.youtube.com/watch?v=evh7rzvTBh4nThis helped me too much nthank you DrAmine n
    • DrAmine
      You can use Moving Frame of Reference (or like in the Video) and here you need to provide the negative of the acceleration or you can use the Rigid Body Motion and you provide the velocity of the sloshing Tank /carn
Viewing 5 reply threads
  • The topic ‘Wave generation simulation (UDF error)’ is closed to new replies.
