Water phase velocity and multiphase assymetric model mixture axial velocity definition
    • Lugia_06
      Hi everyone,
    • Amine Ben Hadj Ali
      You have single velocity field so you cannot get the velocity field of particular phase: all phases moves at the same velocity.n
    • Lugia_06
      nSorry I still cannot understand the single velocity field part, I was thinking Fluent would take water velocity and air velocity separately, and I think in physical world it is truth that the water droplet should travel faster than air due to gravity? Would you please explain further on this?nBest regards,nLugia_06n
      No. If you using VOF or mixture model without slip a single momentum field is solved. n
  • The topic ‘Water phase velocity and multiphase assymetric model mixture axial velocity definition’ is closed to new replies.
