Warning while using the External Data utility for Transient Structural analysis
    • Akira
      I am using External Data utility for imported pressure in Transient Structural analysis.
      The pressure is imported and the model is solved but I have the following warning:
      "The program controlled pinball grew more than 10% of the source point bounding box maximum length. Check results carefully."
      So, how can I solve the problem?
      Someone said it could be solved by specify a pinball larger than the gap between the source and target nodes.
      Where can I specify it?
Viewing 0 reply threads
  • The topic ‘Warning while using the External Data utility for Transient Structural analysis’ is closed to new replies.
