Warning: “Material number should normally have at least one MP or one TB type command…”
    • helen.durand
      I am currently running a transient structural simulation that receives temperature data from a transient Fluent simulation.
      In the structural simulation, I am receiving the following warning:
    • Dragana Jandric
      What is the version that you are running? Can you please check if element 3394309 is contact element?nThere is no specific documentation for this message. The MP and TB commands are used to define material properties. Calculation of energy and possibly other solution data requires that certain material properties exist. If element 3394309 is contact element the material properties would not be needed for contact elements.nGenerally, we can ignore this warning if it comes up for those elements which do not require MP or TB input.n
  • The topic ‘Warning: “Material number should normally have at least one MP or one TB type command…”’ is closed to new replies.
