February 10, 2025 at 3:23 pm
dongsuk.kim
SubscriberHello ANSYS Community,
I am working on a project where I need to visualize the principal stress with the largest absolute value in ANSYS Mechanical. I have calculated the principal stresses and used APDL to determine which principal stress has the largest absolute value. However, I am having trouble displaying this result directly in Mechanical.
I have tried using the Commands (APDL) object to calculate and store the results, but I am unsure how to make these results accessible in Mechanical for visualization. Specifically, I would like to create a contour plot of the principal stress with the largest absolute value.
Here is a brief overview of what I have done so far:
- Used APDL to calculate the principal stress with the largest absolute value.
- Stored the results in a parameter or named selection.
- Attempted to create a user-defined result in Mechanical to visualize these results.
Could someone please guide me on how to properly visualize these APDL-calculated results in Mechanical? Any help or suggestions would be greatly appreciated.
Thank you in advance for your assistance!
PS. Below is the snippet Command I put in Solution.
/POST1SET,LAST*DIM,LARGEST_SIG,ARRAY,NUMNP ! Create an array to store LARGEST_SIG for each node*DO,I,1,NUMNP ! Loop over all nodes*GET,S1,NODE,I,S,1,PRIN ! Get the first principal stress*GET,S3,NODE,I,S,3,PRIN ! Get the third principal stress*IF,ABS(S3),GT,ABS(S1),THENLARGEST_SIG(I) = S1*ELSELARGEST_SIG(I) = S3*ENDIF*ENDDO -
February 11, 2025 at 5:14 am
February 11, 2025 at 7:47 am
dongsuk.kim
SubscriberHello, Subodh
Thank you for the answer. I want to let it display the value itself instead of the absolute value so I am trying to implement using APDL. Would you help with APDL code?
regards,
Dongsuk
6625
1311
