November 13, 2020 at 4:00 pm
JHPontes
SubscriberHi all, nI need to use a visco elastic materail in my analysis and already have the data for loss factor and storage module vs frequency. I have been reading that is necessary to use prony-series to us it, but i don't know exaclty how.nThanksn -
November 16, 2020 at 2:36 pm
John Doyle
Ansys EmployeeIf you have experimental viscoelastic data in frequency domain (i.e. frequency dependent storage and loss moduli), this can be used to calculate prony coefficients in time domain using MAPDL curve fitter.nPlease refer to Section 6.2 of the Material Reference Doc for details on viscoelastic curve fitting. Also, if you have access to ANSYS customer portal, there is an example worked out in KM 2036139.n -
November 16, 2020 at 5:02 pm
November 17, 2020 at 5:15 pm
John Doyle
Ansys EmployeeTranslate your graphs into one tabular txt file that looks something like this:n
Where first column of data is frequency, second column is storage modulus and third column is loss modulus.nThen, you can use the curve fitter in MAPDL Preprocessor to run curve fit to generate prony coefficients in time domain. You will probably have to seed the initial values of tau (relaxation time) to get a successful fit, keeping in mind that the frequency is inversely proportional to time. nThe result would look something like the screenshots below:n n
n
November 19, 2020 at 5:25 pm
JHPontes
SubscriberOnce again thanks for your answer.nI have done the translation from the graph to a .csv file.nWhere can I find this MAPDL Preprocessor? nSorry but I am used to ansys Workbench Interfacen
Viewing 4 reply threads
- The topic ‘Visco elastic material using loss factor and storage module’ is closed to new replies.
