December 18, 2018 at 2:32 am
samLeap
SubscriberWhen placing a plan view in spaceclaim, the orientation is not quite right. The snap to face was used to place the PLAN view, but it is not in the right orientation, the view needs an in plane rotation so it is placed appropriately. What controls the local XY axis of the initial placement ? this doesn't seem to be tied to global orientation as part is tilted somewhat.
Even initially default plan view was tilted in 2 planes which is why snap to face had to be used initially.
Any help appreciated.
December 18, 2018 at 7:19 am
Gaurav Sharma
Ansys EmployeeHi samLeap
For a part which is not inclined with global axis, we can create a plan view and the same can be called in the design sheet. I tried this approach by creating a plan view named "tilted" and it appears to be working fine for me:
Can you please elaborate more on whats going wrong at your end or what am I missing to reproduce your observation.
Thanks & Regards,
Gaurav
December 18, 2018 at 9:41 pm
samLeap
SubscriberYour view is nicely oriented, perhaps because face is rectangular, in my customer's case it is basically an elbow bend transition. he clicks on a circular face, and the plan view has the view rotated 45 degrees in plane.
I will try the named view approach.
December 19, 2018 at 3:11 am
Gaurav Sharma
Ansys EmployeesamLeapÂ
I understand. By any chance is it possible to share the customer's geometry (or a simplified sample) that will help me reproduce it at my end. It seems like an interesting case to discuss with development.
In case the model is confidential, you can send it through e-mail to us at ansys-discovery-support@ansys.com
Thanks & Regards,
Gaurav
December 20, 2018 at 1:19 am
samLeap
SubscriberI asked customer for model, but he is unable to share. He manually did a planar rotation.
December 20, 2018 at 10:57 am
Gaurav Sharma
Other way round can be having a plane placed at the desired location and use a plan view with reference to this plane. That should help.
Please let me know if I can provide any further assistance.
Best Regards,
Gaurav
- The topic ‘view manipulation in spaceclaim drawing’ is closed to new replies.
5834
