December 1, 2023 at 1:49 am
matthew.fig
SubscriberHello,
I am using transient thermal to simulate a small region of a half sphere heated by a heat flux. I want to see how the surface heats up and so I created a Path and then I plotted the temperature along the path. That worked well, but the thing is I'd like to be able to animate the temperature rise along the path. I see there is no way to do it in Mechanical, so I thought I could simply export the temperature values along the path for all the time steps and produce the animation in MATLAB.
The problem is that I have to manually update each time step through a process (see the graphics below) before I can then export the data to be analysed and animated externally. There are hundreds of timesteps and so this is not practical. Is there a way to export all of the data along the path or in any form that could be used to do this? I need each time step to be accessible.Thank you.
December 5, 2023 at 11:08 am
Aniket Chavan
Forum ModeratorHave you tried to use the multi-object export extension here: Ansys Store Multi Object ExportV1.1 created by Ansys Inc ?
It also has source code, so you can change it to suit your needs.
You may also want to take a look at https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v232/en/act_script/act_script_examples_export_figures.html , https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v232/en/act_script/act_script_examples_duplicate_result_object.html and https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v232/en/act_script/act_script_examples_export_result_images.html
-Aniket
- The topic ‘View/Export animation of surface heating along a path’ is closed to new replies.
5809
