Vibration Analysis
    • mdmech.mech
      Hello All,
      I have modelled an oil-filled tank. It is subjected to a vibration of 25 mm/sec for a period of 2 seconds. I want to ensure that the designed component or parts are within the yield strength of the material. Can anyone suggest a procedure to perform the analysis? I don't know how to start this analysis. Some guidance would be very much appreciated.
      Let me re-state the vibration load.
      • Peak velocity is 25 mm/sec for a sinusoidal ground motion.
      • A period of 2 seconds is a frequency of 0.5 Hz.
      You want to know the steady state response of the structure.
      Let's put aside the fact that the tank is oil-filled for now because it makes the model slightly more complex and just focus on making a model to simulate the stress in an empty tank.
      The analysis you want is called Harmonic Response.  It requires a Modal analysis to build upon.
      Take the free courses on Harmonic Response and Modal then come back when you have attempted that for the empty tank.
      /courses/index.php/courses/harmonic-response-analysis-in-ansys-mechanical/
      /courses/index.php/courses/harmonic-analysis-of-structures/lessons/intro-to-harmonic-analysis-lesson-1/
      /courses/index.php/courses/modal-analysis-in-ansys-mechanical/
      • mdmech.mech
        Hi Peter,
        As per your suggestion, i have completed the modal analysis course and the tank natural frequency extracted. While attempting to do the harmonic analysis followed by modal analysis, I could not able to insert the 25 mm/sec as a velocity for the frequency of 0.5 Hz. Can you please guide me for further process.
      Convert the velocity to acceleration by taking the derivative. The equation for the velocity is A*sin(w*t) where A is 25 mm/s and w is the circular frequency. Convert the 0.5 Hz frequency into a circular frequency. It's not important that the equation changes to a cos function.
      • mdmech.mech
        Thank you Peter,
        velocity (A) = 0.025 m/sec, w = circular frequency is 3.14159 rad/sec, from this acceleration I have got is 0.2467 m/s^2. Am I correct?
        Mean while, how do I model the oil filled in the tank? Please suggest a procedure.
        Thanks in advance
      How did you come up with that number? I don't think it is correct.
      Is the tank completely filled with fluid or is there a free surface with air or other gas at the top?
      • mdmech.mech
        Hi Peter, From Internet, I have found a formula,
        x = 0.025 m
        acceleration = 4*π^2*f^2*x  = 0.2467 m/s^2
        I am not sure, which method is correct
        As you suggested,
        f = 0.5 Hz
        A = 0.025 m/s
        w = 2*pi*f = 3.14159 rad/sec
        velocity = A*sin(w*t)
        t = 2 seconds
        acceleration = A*w*sin(w*t) ---- As you said I have taken the derivative
                            = A*(2 * pi * f) * sin(w*t)
                             = 0.025*(2*3.1416*0.5)*sin(3.1416 * 2)
                             = 0.00859 m/s^2
        Please give me a suggestion as to which value of acceleration I should take.
        The tank is half filled with free surface with air at the top.
      The formula from the internet is to convert a displacement to acceleration. You have a velocity so you take the derivative of the velocity and you wrote a correct equation for acceleration.
      The amplitude for the acceleration is A*w = 0.025*3.1416 = 0.07854 m/s^2.  Don't evaluate the sin(w*t) term, which you got wrong because you didn't use radians, but you only want the amplitude anyway.
      I will reply later after I find a reference for adding the fluid to the tank. That question has been asked before so you can try searching for it also.
Viewing 4 reply threads
  • The topic ‘Vibration Analysis’ is closed to new replies.
