July 26, 2021 at 3:36 pm
NimaNZ
SubscriberHi everyone
Is vertex average suitable for monitoring variables (velocity and pressure) on probs (defined points into the domain) in transient simulations?
Thanks
July 27, 2021 at 9:06 amRob
Forum ModeratorThe best way to judge is to create the point and then use the surface integrals to check the value of the various options: you need to initialise first. Then pick the one that makes sense. Assuming the mesh is sufficiently refined, vertex mean, max and min should be reasonably close.
July 27, 2021 at 10:36 amNimaNZ
SubscriberThat makes sense; thanks very muchJuly 27, 2021 at 11:19 amDrAmine
Ansys EmployeeShould be equal for a point . The nearest values will be backed to that points
July 28, 2021 at 11:54 amNimaNZ
SubscriberThanks very much
Viewing 4 reply threads- The topic ‘Vertex average’ is closed to new replies.
6269
