Electronics
Electronics
VERSION ERROR
    • alexia.carenini
      Hi, since I'm a student, from 31/07/24 I have the new version of Ansys Electronic Desktop 2024 R2 (Student version), the problem is that when i try to do coupling between maxwell and icepack with 'EM to Icepak' I obtain the following error: The EMtoIcepak extension was built with an older version of Ansys Workbench. Please use this extension carrefully. If unexpected behavior occured, you should rebuild the extension with the current version.
      But the new version of EMtoIcepak extension doesn't exist since it is the same as the one in 2023.
      Thanks
    • Harinath Vudumula
      Hello Alexia,
          I think you are opening the model from AEDT, But it was saying that "it was build in Workbench environment (Maxwell + Icepak coupling through Workbench). Please try to open the model using workbench.
      Thank you,
      Harinath Vudumula.
