October 29, 2018 at 5:52 pm
seventanapply
SubscriberHi,Â
I am trying to verify the tan delta of viscoelastic material in Workbench. The model is simply a 10x10x10 mm cube. Transient structural is chosen.Â
For the part of Shear modulus and bulk modulus, I obtained the experimental data from DMA and import those data points into Engineering data. And I have already verified that if there is a constant stress, then a creep compliance curve is obtained which is matched with my experimental data of creep compliance.
For tan delta,
I measured the storage modulus vs freq curve from DMA and import those data into WB by APDL commands.
Then I set my pressure as a kind of sinusoidal pressure upon the top surface. The function of pressure is as follow.
Pressure=-0.4*sin(6.28*time) if pressure<0
otherwise pressure=0.
Those data are imported by XML file. I am pretty sure the pressure is correct. Here is the screenshot.
Other boundary condition is a fixed support at the bottom.
According to the definition of tan delta, delta is a lag phase angle between stress and strain if the input is a sinusoidal stress.
But I cannot see any phase lag in my results.Â
Can you give any suggestions? or maybe I made some conceptional mistakes? Should I do it under Harmonic analysis?
Thanks in advance.
February 27, 2019 at 8:42 am
caogang7758
SubscriberI recently also find out that transient structural analysis does not shown any phase lag and energy dissipation when you use prony series viscoelastic.I feel puzzled.
- The topic ‘verification of tan delta for viscoelastic material’ is closed to new replies.
6495
